Antenna on roof?
Old 03-08-2011, 01:31 AM
xxxxsh4d0wxxxx's Avatar
Originally Posted by Rocky87
talked to the parts manager and the fin is for onstar and xm, they are built together. i even took mine off and i couldnt get a signal so i guess that solves that.
Sweet thanks for the clarification!
how did u take it off? isnt it glued to the roof?
No, if you have the "fin", it is detachable from the base.
Old 03-08-2011, 01:47 AM
EmperorJJ1's Avatar
oh lol one of the guys down here popped his off once but we all thought he just broke it
Old 03-08-2011, 02:07 AM
Acey's Avatar
I hate me lil XM antenna, which I have never used. I'd slice somebody if I had that big ass Onstar fin. I haven't tried to remove it tho.
Old 03-08-2011, 02:41 AM
EmperorJJ1's Avatar
i wouldnt... where is it btw
Old 03-08-2011, 02:53 AM
Acey's Avatar
It's on the roof at the back, near the top of the rear glass.
Old 03-08-2011, 02:55 AM
EmperorJJ1's Avatar
esh.. if u do decide to give it a shot i would look around for wires. if it looks like theres none then that means theres a hole drilled like the shark fins. Id also be worried about messing up the paint BUT in comparison a hole is much worse then minor paint damage
Old 03-08-2011, 02:57 AM
Acey's Avatar
Yeah it probably wouldn't be worth the risk. If I had a fin on the other hand... that bitch is coming right off.
Old 03-08-2011, 03:01 AM
EmperorJJ1's Avatar
true dat homie
Old 03-08-2011, 01:51 PM
NCC-2000's Avatar
The roof antennas leave holes. On mine there are actually two separate holes under the antenna, one large and one small. The wire(s) coming from the antenna has a connector pretty close to it, so it's easy to disconnect and remove, but you still have the holes to worry about.I had to drop my headliner a bit to give me enough room to move in the area to disconnect and unmount the XM antenna, but it's really simple to do.
Old 03-08-2011, 09:04 PM
Rocky87's Avatar
no it snaps onto the base, they are put on when the car is PDI'd. no glue at all
chefhhr
10-26-2015 10:36 PM
dieGone
09-23-2015 10:20 AM
slugsucker
08-26-2015 07:14 PM
slugsucker
08-26-2015 07:11 PM
Quick Reply: Antenna on roof?
