attaching amp to factory battery
Old 03-20-2009, 04:18 PM
brickloaf's Avatar
Originally Posted by Spun
Make sure you have a nice warm place to work with 0 guage
It tends to get a bit stiff when its cold.
It was cold as hell when I did my 0 guage from the battery to the fuse box, had to use a hair dryer to warm it up in order to bend it in some places
Sorry didn't flip to the second page, the post was directed at brickloaf
i was thinking about getting 0 gauge for the neg to ground, positive to alt, and engine to ground, but the cobalt already has 4 gauge so i didnt think it was needed.
Old 03-21-2009, 12:02 AM
stinkyfisherman's Avatar
Just some food for thought,
whats the difference from ac voltage in a house and dc voltage in a car other then the obvious alternating part? they are both electrical circuits with a positive and a negative in AC the "ground" is a completely separate conductor and all its purpose is to be a protection device, in the case of over current for some reason electricity should flow along this ground and hopefully prevent ur house wires from melting and causing a fire.
In a dcv car the "ground" is nothing of the sort it is the negative circuit hence removing the battery ground and ur car electrical components no longer work. Assuming you had a very basic vehicle electrically and the battery was up front like normal... play along with me and we'll assume the alt wasn't connected to the engine electrically with metal and the engine not connected to the body and each electrical component that normally gets its negative via that connection had its own wire running straight to the battery... If you were to eliminate the body ground and use wire to connect the battery and alternator would the car still work? (remember very basic old vehicle, no computer ect)
The answer is yes all dc needs is a pos and neg and as long as they are safely connected electrically it would work exactly the same but it seems a lil redundant to do all that work to make sure the negative isn't touching the body and making a body "ground" as we know it today. Along with the fact that in cars today there's so many different electrical components that "ground" to the closest place they can find. One could argue the only reason for a body ground is to save money. Why pay for tons of copper wire when your surrounded by metal? The second reason for the body ground is like you stated resistance. the fog lights or whatever in the engine bay that's grounded there will have a better connection resistance wise then running a thin wire all the way to the battery in the back. The only way for it to be a better connection resistance wise were if you connected them with a wire thick enough to have a lower resistance then the body ground. Running 8g or whatever for EVERY electrical component to ground straight to the battery is not only obnoxious and boarderline impossible but again expensive.
Copper is a better conductor and has lower resistance then steel. so if the battery is close its will have less resistance to ground to the battery directly
Well put.
Originally Posted by polarbair
I'm sorry. apparently in typical fashion, I didnt clarify my question. My bad. Yes, Positive to positive and negative to negative, that part I got. My question is in looking at the factory battery they installed, it doesnt have secondary posts. Do I have to replace the factory connector thats on the posts? how do I make the connection TO the battery?
If there is a screw or bolt on the posts just put a ring terminal on the wire from the amp and put the screw/bolt through the posts with the ring terminal sandwiched in between the two
Last edited by stinkyfisherman; 03-21-2009 at 12:02 AM. Reason: Automerged Doublepost
Old 03-21-2009, 01:51 AM
Spun's Avatar
My stock Positive terminal had a screw sticking up out of it. It was like a flat piece of metal with the hole for the positive terminal of the battery on one end and the screw sticking up on the other end. I just used that screw/bolt on the positive terminal, one of the nuts that held the stock sub in fit on it (10mm).
Old 03-21-2009, 03:33 AM
EmperorJJ1's Avatar
Originally Posted by xray_racer
I am no expert, but I have had some experience and I know when I put a new engine in my '70 Camaro and didn't connect a wire from the battery to the frame of the car the starter would not turn over. As soon as I connected a wire from the neg bat terminal to the body it started right up. Someone that understands this better please speak up, I would like to know. Thanks
right because all cars use the body of the car for the negative. since the starter uses electricity to work and electricity needs a full circuit (pos and neg) connecting the battery neg to the body completes the circuit as intended/built from the factory. All new cars must have a connection from the neg batt terminal to the body
Originally Posted by stinkyfisherman
Well put.
thanks
Old 03-21-2009, 03:42 AM
brickloaf's Avatar
kinda unrelated, but is it worth it to upgrade the big 3 wires from the stock 4g to 0g? 4 seems like more than enough for a balt
Old 03-21-2009, 04:00 AM
EmperorJJ1's Avatar
??? it would help probably help but with the 4g stock its not "needed" persay
Old 03-21-2009, 08:19 AM
Sp33dyG's Avatar
unless ur putting a big system back there like lets say anything abouve 1,500 watts or more would require to move up to 0gauge
Old 03-21-2009, 10:51 AM
EmperorJJ1's Avatar
obviously if you go with something big it would help to do all that. and while brick probably has enough power to be boarderline i don't think he would notice a huge difference from how he is gonna set it up now
Sl0wbaltSS
11-21-2018 11:11 PM
Tupp
2.2L LAP Performance Tech
01-02-2016 12:04 PM
dennis69
10-20-2015 04:49 PM
Tupp
09-30-2015 08:18 PM
c_m_shooter
09-27-2015 04:40 PM
Quick Reply: attaching amp to factory battery
