Audio head unit help
I had a question about the difference between a Single DIN unit and a ISO DIN unit. I found a gauge pod that is a Single DIN, and I want to know if in a standard Double DIN harness, can I fit the Single DIN pod and an ISO DIN head unit in it. I don't want to mess with the factory airbag in the A-pillar so I'm looking to put a pod in the Head unit. Any help would be great. The link to the gauge pod is below.
http://www.glowshiftdirect.com/index...ROD&ProdID=253
not really... the double din kit has a big hole for the double din HU and the single din kit has just the single din opening and a pocket. ISO mounting is screwing a mounting piece on both sides of a HU and it doesnt reuquire a physical "kit" persay.
That might work if they are no bigger then an acutal single din, but your also not going to have the support in the middle of the two. Look to see if theres an acutal kit with 2 single din openings
http://www.bestkits.com/ViewImage.as...i/BKGMK352.jpg hear is one i think best buy will have it
Hey, thats what I"m looking for. Thanks a lot. I"m checking with glowShift to make sure it's exactly a Single DIN. It looks like should fit with little or no modifications so we'll see. Thanks again
agentirons
10-16-2015 02:11 AM
09-28-2015 12:51 PM
