Audio Issue. Please Help.
Hey guys, I just put my 2 12's and my amp in my car this morning and I have a problem. My amp seems to not be communicating with my subs to give them the juice. The amp powers on fine and everything can be programmed through the after market H/U. I have no idea what the problem is and would appreciate any input anyone has to offer. Thanks in advance.
i had that problem if its the same one i had in the back of your head unit you should have 1 output plug that says subs...you will need a female(i think thats the right1) to turn that 1 output plus into 2 so you can run the rca wire to the back of the headunit
heres the link of the adaptor that youll need if thats your problem
http://www.google.com/products/catal...59590439091863
Well guys I had this whole system hooked up and working great last summer and I re-installed the same way I did before. RCAs are brand new. I just opened the new pack this morning. I'm baffled. I have no idea what the problem is. Speaker wires are good, no positive/negatives are crossed.. IDK.. Thanks for your time guys, if you need any more info let me know.
My H/U does not have Mono, it has the 2 input ports for left/right. Thanks!
Brand new!
Brand new!
