Audio pictures
Audio pictures
I'm just wondering what everyone's trunks look like,
and also. Can anyone please take pictures of maybe where they put there ground wire and then there power wire to there amp please. Thanks guys!
If your batt. is an ac delco like minewas then when you lift the red cap in it you will see a seperate bolt sticking up from the metal part that attaches to the batt. post. Use a 10mm nut and a deep 10mm socket and attach your power wire there , as for the ground, no longer than 2 feet, so it all depends on where your amp is , if its up by the back seats, use one of the bolts that hold in the seats. If its in the back of the trunk then try one of the bolts that hold the base to he antena up, or one of the bolts that hold the trunk latch on, becareful doing that though, those latches are tricky, they don't want to go back on all the time.
Whatever you do make sure to sand or scrap the paint away from the ground area, place a fuse 6" away from the batt. and don't ground it to any of the bolts that hold the taillights in
idk. ill think about letting u drive it. and i'd pay u. im sure u wont charge as much as best buy or circuit city.... i hope
and i remember u said the auto tranny is rated to like 300tq or something, yea well the 5spd is rated to 170 tq. im almost there lol
Hey thanks it wasn't very hard to make and if i had more time and work space i would be willing to make them for people maybe ill just put it out there and see if i get some type of response.
