Avic-D1 install question? to deep?
Im trying to put my AVIC-D1 in and i cant push it back far enough? wtf? i searched and some of you have them installed but i cant push it far enough back??
im like an inch away from the bracket touching the dash
When I put an aftermarket one in my cavy, cougar, newer cavy, and my boss's suburban, there is a plastic piece in the back that holds the stock radio flush. The stock radio is much bigger but not in depth, but height and length.
Grab some pliars or tin snips and looks towards the back to see if there is any plastic in the way that could be blocking the radio.
Ive got the exact same problem as you. My 2 din system wont go in. My instaler said its 1. the main airflow vent and 2. that beam looking thing is supposed to be the dash support.
So now its sticking out about 1/2 an inch He also said that only the base models have that problem
push in , then slide up....kinda the same way you would have to put the stock on back in
and that will work. still a huge pita through
For real? so its sitting in there properly now? well i guess im gonna have to try some more. What dash mount did you use?
