AVIC-F700/900 Bypass
Ok so I dont know how many people have the AVIC-F700 or AVIC-F900 but, here is the best way to bypass it and it works great.
On your RCA harness you have the mute wire (yellow/black). Its on the last pin out on the harness top row looking at it.
Pull it out and move it down one and over 4 spots to the open spot inbetween the two black wires that turn into the rca's. Glue it in so you know it says. I use super glue, just a small dab too much will get messy.
Then ground: mute wire (yellow/black), ground (black), and parking break (light green)
DONE! Here is a picture for some help...
The top picture with the red circle is the original pin out of the mute wire (yellow/black)
The bottom picture with the red circle is where it needs to end up.
Hope this helps someone out there!
