bad wideband gauge??
i has a problem. my wideband shows 10.0 all the time. during idle, WOT and also out of the exhaust....is this a indication of a bad gauge?
Or maybe you have a issue with your car, look at the stock narrow band mili volts to see wut it says. Also check your connection on gauge and verify its all good before you consider the gauge being faulty. usually when it shows 10.0 it is the wiring not wired correctly, or a bad connection. or wot fuling is off lol. but somtimes the sensor is bad
my aem did something similar except it was stuck at 15.9, then it unstuck itself somehow. don't really know why as it never did it again. only thing i can think of is it was extremely cold that day and it was frozen
n20saturn
09-30-2015 12:26 AM
