battery bolt
battery bolt
when u look at the postive terminal on the battery there is a bolt coming up that has no nut on it.. i was wondering if anyone new the size of that bolt because i would like to buy a nut for it to add some accessories to my car.?.
great thanks for your help.. if u can't find it is there any way in measuring the stud to find the correct one? also where did u mount ur neg cable?
I have the ground going to the bolt where the battery grounds to the chassis.
thanks bandit. when you installed your system did you disconnect the negative battery. is it really neccessary as long as your careful?
With amps that have recessed power terminals like mine though you have to be careful the positive wire isn't hot when you hook it up since if it's hot when you hook it up you'll get a big spark since the area surrounding the terminal is ground. I left the inline fuse disconnected when I did all the amp wiring and connected it when I was done.
so if i leave the fuse out when hooking up the postivie wire i should be fine then.. thanks
it's just the negative cable i take off right.. i don't touch the positive?
will it spark at all when reconnecting. thanks for the information
PS Where in NY are you from?
