battery died, i believe my sound system ran it dry
Hello everyone,
I have a complete upgraded system in my cobalt 2007. I have a aftermarket pioneer radio, hifonics zeus 5 channel amp, 10" pioneer sub in ported box, infinity kappa component set in doors and rear. I have a external fan wired on the side of my amp as well. I have aftermarket m3 blinking mirrors. I have 24k miles on my car and my car audio has been in about a 8 months. I went to start my car today and the battery was completely dead so took it to autozone and had them test it and it would not charge. I went and bought a new battery today 600 cca from walmart but believe its going to do drain it again. I know this is not a solution of a battery but i am out of state in florida and driving back to texas tommorow so I needed a fix for now. I really need to find a solution for this or I am going to rip out my system as its not worth it. I read from so many sites to get a capacitor and then read there hard on your alternator. I also read to get Kinetik battery and then upgrade your alternator. My amp is the hifonics zxi 8006. I am running it like this.
The ZXi 8006 provides up to five-channels of amplification, 4-channels producing 110W RMS @ 2-ohms of real power for Front Left and Right channels, Rear Left and Right channels, plus the 5th channel, a 300W RMS subwoofer channel for the most pure bass you have ever heard.
Can someone please clarify with what i need to do, PLEASE!
What about a capicator? Second Battery? Send out my alternator? Upgrade to larger wiring on battery and alternator?
thanks,
Josh
thanks,
Josh
Ill clarify a few things. Kinetiks is WAY overkill for your system and A cap is 100% COMPLETE garbage. If I were you and you wanted a good reliable setup I would Go get yourself a good set of optima batteries. one red top for under the hood and one yellow top for the system. You can go with a Kinetiks battery but I think you are spending too much money for no reason. untill you have atleast 3k watts amp you dont need to go the kinetiks route. I didn't jump up to the kinetiks line until I was running over 10k RMS.
.02
.02
buy a battery
hook up the battery straight to amp (battery sits in trunk)
battery positive to amp positive
battery negative to amp negative (works as ground)
look at his positive battery post, you can see 2 wires, the 0 gauge is for his amp and im not sure what the other smaller wire is but i know he has 0g wire coming from his alt so its obviously not coming from there
so yeaaaa im pretty sure you can just hook up the battery straight to the amp w/ no alternator
.02
.02
Hello everyone,
thanks,
Josh
thanks,
Josh
.02
.02
so that 4g is what was connected to the front
yes i have played it with the car off while washing my car and stuff.
is there an upgrade alternator out for our cars as i read online you have to send your stock one out for rebuilt for more power.
I looked in my photobucket but All I have left is the old for sale pictures. I sold all my gear last summer. heres what I had... I WANT TO REPEAT THIS, ALL MY **** WAS SOLD!!! These were just the for sale pics...
(2) DD9910's Ran these for a daily setup with 5k RMS EACH.
(1) DD9910Z
If anyone is REALLY into SPL, you know what this driver is. This bitch cost almost 4 grand with all the options. I ran 10k RMS to this in street A for local comps.
(1) of (3) DDZ1A's I had.
(1) of (2) of my DD9917s. These are the (2) 18's I ran 7K RMS to EACH.
Dude, This kid is running HiFonics amps...
OP, Please trust me when I say you DO NOT need an upgraded alternator for your current setup. until you get to around 2500-3000RMS is when you need to think about upgrading ur alt.
Im just trying to save you some coin...
(1) DD9910Z
yea you dont need a new alt, idc what speedy says
and damn now i want some DD subs, i cant believe you can run 5k in to a 10'
That Z driver is a 10 and you can run 10K of CLEAN power to it no problem. Im a DD fan boy (Or I should say I WAS) but They really do make amazing products.
http://www.google.com/products?hl=en...num=1&ct=title
Josh
So your saying my battery will die again even if i dont run my radio anymore when the car is off. Also, which agm deep cycle would i need as i did a search on google and came up with a bunch.
Josh
Josh
and
DD subs arent the only subs u can run 5k into a 10" theres also DC lvl 5's that u can have made in 10" BUT ud have to mount it inverted cuz the mag is bigger than the mounting hole and DC is ALOT cheaper than DD is
(not bashing on DD either)
