Battery keeps dying
Its your battery vent, some dont need it, some do. If you dont see it on your battery then you dont need to plug it in, otherwise your battery is leaking vapor into the cabin.
Whats the temp like in your area? The Cobalt battery is in the trunk, it never gets any heat so in the winter its always dead cold in there. That kills a battery faster then anything
im trying to help in this thread but i cant stop looking at the two hot chicks making out...
i would suggest testing your alternator to see if its bad. get the car started and running. while its running, remove the positive terminal on the battery. it wont shock you, just dont touch the negative terminal at the same time lol. if your car continues running, ur alternator is good and u probably need a new battery. if it dies, that means your alternator is dead and you need a new one.
the vapor tube is mainly bullshit... if the battery has it its sealed so it doesnt need it. the reason its there is because thats not good enough for regulations on millions of cars. so they make batteries or more so battery cases with those on the slight off chance your battery is way over charged and breaks the plastic seal
firehawk618 (11-19-2015)
Lol yea but it worsk, especially if ur broke like me
#36
good ****! if i leave my car sitting for like 10 hours with the radar on it will kill my ****. and when i leave my radar off it feels like the car struggles to turn over. i might have to get myself a new battery as well.
#37
Oh how it feels to be a
I pretty much had the same problem. I would let the car sit and it wouldn't start. Well took it to advance they said the battery was fine. Well went to the dealership my dad works at had them test it and the battery was junk. So yea don't believe what them hacks at parts stores have to say. Sorry if anyone works at a parts store on here.
#38
My battery keeps dying when i let my car sit for 2 days, the battery is 100% dead the remote on my keys wont even unlock the doors hell i cant even pop my trunk from the button on the inside of the car. I already had classic Chevrolet replace my battery and clean my cables but im still have the same problem. I was just wanting to know if any of you guys have had this problem before and if this is a common problem with our cars and what i should do about it?
Any input?
Would the tune have anything to do with it?
Any input?
#39
Watching the voltage whenever the car sits I see that when running the charge goes to 14.5v roughly, when shut off.. it drops to 12.7v, after a weekend of not driving, it was 10.9v.
turning the ignition over dropped the 10.9v to a 9.0v briefly before the car started charging back to 14.5v. no choke in start up.
everyday I check the volts before heading into work and check it after. usually the day is between 8-10 hrs long. When I shut off the car it shows a 12.5v-12.7v, at the end of the day its usually a 11.7v-11.9v. same with going to bed and seeing it in the morning.
EDIT: I AM NOW TALKING ABOUT MY NEW BATTERY. lol. I cant tell you what my bad battery read for volts but Im pretty dang sure it was alot lower.
#41
I brought the battery to Autozone the girl hooked up the meter just fine, I watched her do it... I saw the number. It was a bad battery.
#43
#44
Are you SURE the battery is dead? Reason I ask...I just went to open my car...ZIP! No fob entry..no lights. I did unlock the doors with my key though. Turned out the negative battery terminal was loose! The terminals on these cars are pretty flimsy and can disconnect very easily.
#46
Vehicle Battery Saver
Vehicle battery saver mode automatically shuts off your detector after 3 hours if you forget to turn it off. The timer is reset if the detector is unplugged, turned off or any button is pressed before the timer has expired. The detector will alert you with an audible and visual warning (text units display "PWR OFF") before shutting off. Units with option select mode can turn this feature off. Most detectors draw around 300mA of power or just over 1/4 of an amp. When the vehicle battery saver kicks in, this power consumption drops by 90%.
What does this mean to me? Well lets assume that the radar detector is left on and the vehicle's battery has a 60 amp/hr rating (average sized battery). The above vehicle would have a dead battery in about 200 hours or approximately 8.3 days. Roughly the time for an 2 week vacation or company trip. Having a detector with a Vehicle Battery Saver feature will extend the battery life to about 2000 hours or 83 days making the travel home from that company trip a stress free one.
Note: These times are approximate and do not take into consideration the normal battery drain from the vehicle's electronics. The Battery Saver feature can be manually engaged by holding the city button for 2 seconds. Within 10-15 seconds the unit will turn off as described above, we call this turbo mode. If you tried to enter City Mode and the unit turns itself off, the city button was held too long.
Also found this:
2007 Denali Xl Dead Battery Problem - Dealer Blames Radar Detector? - GM-Trucks.com
If your radar detector is pulling 250 mA, according to GM, your battery will rundown within 3.3 Days
#47
You can also check for parasitic draw via a test light. Discoonect the negative battery cable. Hook the clamp end of the test light to the negative battery terminal and the test lead end to the negative cable (make sure the cable stays disconnected from the battery). If the light glows you have enough amps to drain the battery. You can determine where the draw is via process of elimination. Unplug the detector. You can pull fuses (alternators and starters can be culprits).
I haven't looked to see what the life expectancy of the OEM battery is but usually if you have a five year battery you are on borrowed time after 4.
#49
#50
hmm.. I'm in for more details, I had a 'problem with my security' system an my it drained my battery... dealership said my it jus had a couple dead cells an then it jus drained the rest by itself which caused the security system to go off.. I honestly didn't care cuz they gave me a new one an installed it. I just want to know how it started dyin on its own.
I have a cobra radar detector thats always plugged in 2 btw... my car was sittitn there for like 12 hrs....
