Which Battery Should I Get?
i have a 2006 LS with subs and i am in the process of installing aftermarket power windows. My stock battery just died and i need to get a new one. Which would everyone recommend? I need to know the exact size and everything because i have looked around and no batteries are highlighted for my car
o wow... umm... really if its a lease... you cant put the battery into the stock location... so dont...
recharge the battery, get a kinetik 600 or 800 or 1400 depending on how much you use and run it in series
just for reference... for my car (2007 cobalt coupe lt) with power windows, power mirrors, dvd head unit, 1500 watt subs, 400 watt speaker i used a kinetik 2400 and i can run my subs on high for an hour or so before i see any delay in voltage (with the car off...) (my key fob takes 2 or 3 seconds to unlock the car)
What about the SVR's? I have a SVR battery 34/78DT and add Power windows, gps, RD, pillar gauges, GPS, security, and 1,100 watts system. all runs good never have voltage drops
is it leased?
oh it was a bitch... cut my hand open alot... infact i thought i sealed it, but after going through a drive through wash found out there was a little water... i sealed it though... so its fine now... but luckily nothing got messed up
mount it in the trunk? remove that ngt lol
lol id gladly upgrade but theres no way in hell it would fit there. way to wide. an 1800 would but swapping the stock batt to a kinetik is low on the list of **** i need to do right now. HIDs and a super awesome amp are next but i need a **** ton of cash for a double din ive been wanting
