best grounding post
best grounding post
there is to brackets right behind the seats under the carpet. the brackets have huge bolts in them, they look like a good spot to ground my amp on. Has anyone else tried this spot for grounding yet?
Also do all amps have protection mode? I just bought this alpine amp and it doesn't say anywhere in the manual that it has protection mode.
well i would rather have my amp have its own grounding post. plus the amp is mounted near my seat so that would be the closes grounding point. but i'm not sure what that bracket is being used for? if it's connected to the gas tank is that safe to ground to?
if you pull out the trunk mat, (climing in through the back seat) their are 2 bolts with mounts, (the mounts are black) either of the bolts will work. they are both grounded. if that doesnt help i can get pictures up tomorrow. and look on the net to see if your amp has a protection on it. most amps do but then again.
edit:: the spot you have in your original post is what i am talking about
theres one bolt on one side of the trunk and another bolt on the other side of the trunk holding a black bracket in place... is that the one ur talking about?
Truck bolts
I would advise against using those bolts. That's where mine are now and there is not a very good ground connection there. My sub levels increase and decrease with my shifting using that bolt. In fact I found this thread by looking for a better place in my trunk to ground.
Domestics Pwn
I have my amps grounded there right now (after moving them from another point in the trunk).... Since I moved them to the rear seat bolts i've picked up some engine noise in my speakers.. I need to get off my ass and relocate them to somewhere else.
ground it to the spot where the battery is grounded to
i mean physically where the negative for the battery comes from, ground it there as well
its gonna be the best ground in the car, obviously
