Best place to put Amp?
I made a mock up of the amp rack with cardboard, got it how I wanted it, then cut it out of plyscore. Next, I mounted the amps to it, cut the holes for the wiring, etc. Finally, I carpeted it and cut the carpet with a sheetrock knife where the holes are. It's secured by that one threaded rod with a nut on it that you see (and gravity). The stock box mount has slotted holes, so I put a piece of rod through with a nut on it, slid it into place, then tightened another nut from the front to keep it there. Same thing with the nuts by the amp rack, there is one behind it to keep the depth, and one in front to tighten the amp rack.
I also had my amp in my spare tire well in my Chrysler but in the cobalt there isnt enough room for it to sit right without taking out the spare tire.
