blowing a main power fuse to the amp
hey guys, i was listening to shoulda lean and the first 10 seconds of bass were amazing, then i blew the fuse on the power wire, i dont remember what size it was, but is there any way to prevent that from happening, oh and the fuse on my amp is an 80 so i was going to throw a 70 in the power wire fuse holder, it is a glass fuse
well, the fuse on the power wire im not sure of, but the amp fuse is 80, and it was fine, i used 4 gauge i believe, the copper wire itself is approx 1/4 of an inch, i got it from a local audio store, so i will be fine using an 80 amp fuse since that is what is in my amp
Like creedin said your are over powering it. Either turn down your amps or start upgradeing your electrical system. Start with a small 5 farad cap on that amp. See if that helps.
well, i talked to an audio store today, im going in next week to get an audiopipe waffer fuse holder and a 100 amp wafer, and possibly a 2 farad cap at some point, oh and what length screws did yall use for mounting an amp the the back of the seat?
he said $25 for the holder and fuse
cool thxfor the screw size, you guys predrill or just screw it in?
oh and i blew that fuse with my amp at less than half way, but i cant imagine what it would sound like all the way up, cause it pounds now
i always do listen to him, thats why i ask on here before i buy, but the cap wasnt for the fuse, i was goingto do that forthe light dimming and help out the alternator, but you guys think that price is good for a fuse and holder, its the better version of audiopipes, and it is easier to intall the fuse and is water proof incase i take my car swimming, or make a pool out of my trunk lol
I personally use wafer fuses. I don't like the glass ones...
This is similar to what I use...
http://www.scosche.com/products/sfID.../productID/282
here's the fuse and the link to the one I would use since the wire is rated at 125a max...
http://www.scosche.com/products/sfID.../productID/781
Last edited by Tazmanian_Dvl; 11-07-2008 at 05:28 PM. Reason: Automerged Doublepost
