Blown system Or just Loose wire?
Alright i just now started to have a problem with my System. 1600 watt amp with two 12s. When ever i turn the key over You hear a Thump Thump from the Subs then no sounds comes out of it. Ive tried to turn it on and off a few times and still does it. It seems it wants to only work every other day. I was Figuring a Loose wire due to i still have the stock HU. Any Thoughts or advice?
Turn on thump?
Try putting a 1000 ohm resistor in line with the remote turn on. A lot fo aftermarket amps give you a turn on thump when you use a factory radio. Try this and let me know if it doesnt work. Each case is different.
