Blue wire to stock stereo
K so I got my system out of my Toyota mr2. Everything is hooked up except for the blue wire coming from my amp. Can I hook that up 2 my stock stereo. If so where?
i mean can i hook it up to my stock deck? i have 2 audiobahn 10-12 inch subs and a 600 watt amp. and there is a blue wire that comes from the amp. i think its supposed to go to the deck right???
what do you mean switch? The remote wire is what tells the amp to turn on. so if you ran it to the stereo then it would come on when the stereo comes on and turn off when the stereo turns off. If you run it to an acc fuse it comes on with the car and off with the car. The only other 2 options if you're not running it thru the car is hooking it up to the power so it stays on forever until your battery is drained and your car won't start (battery develops a memory and eventually dies as well) or not hooking it up at all and the amp is a nice shiny paper weight never turning on.
Some people will put a switch inline like myself so my amp turns on and off with the radio but i can also manually turn it off as well. This isnt necessary but an option some people utilize
