Bluetooth/USB radio
Bluetooth/USB radio
So i've been researching and looking around the posts here wondering if this can be done but have not found a concrete answer.
I have an 07 cobalt with the AUX jack and no onstar. From what I know off, the radio can be swapped with another one with the USB port and the dealer just has to reprogram it to unlock it for your car to see it. The the car can use USB sticks/ipod/iphone to play music.
In terms of getting bluetooth, does the car need to have the onstar system for it to work? I have the XM radio if that makes any difference. Is it possible to get a bluetooth module for the newer car radio to see it?
As a second workaround, could the rearview mirror be swapped with a different unit, one with bluetooth and perhaps autodimming. I have heard that there are problems when speaking to other people using this method since the mic can't hear your voice when you are going faster than 80km/h (50mph).
Any ideas/suggestions would be appreciated.
Doing the swap to get the USB port is easy, bluetooth isn't. You'd have to get an OnStar module, and also the microphone and wiring for it, and possibly the mirror. No idea if installing an OnStar module in a vehicle that doesn't have it will actually work or not.
I want to keep my car stock looking, just in case I ever run into the need to sell it down the road.
sounds good,
i saw your post on that bluetooth retrofit post. Did you get that working for you? From what I understood, you could buy that module and wire a mic to the front.
agentirons
10-16-2015 02:11 AM
shawnsseries
09-10-2015 08:29 PM
