Bought a Subwoofer need help
http://www.audio-warehouse.com/web/m...001/detail.asp
/thread lol
also.. prolly wouldn't have payed 100 bucks for that. but GL
/thread lol
its just more efficient money wise. If you get a mono amp you can only run it at half power (4 ohms) where as a 2 channel makes full power bridged at 4 ohm. Plus the fact that most mono amps are more expensive to begin with.
otherwise it doesnt matter. Just look for that 250w at 4 ohms
#39
i am gonna take it to a shop to have it installed... What should i tell them about wires and i want to know if they can make it so my stock sub still works when i remove the enclosure like if i go to the track
#41
i would disconnect the stock sub regardless...if you go to the track you shouldn't be worried about having bass. plus if you remove the stock sub that will save u some unnecessary weight and gives you more trunk space. try to test fit the sub in the trunk before you go about spending anymore money because it really is a tight space to work with.
