Bypassing the factory amp
How do you bypass the factory amp? I got a harness from Crutchfield for the deck. When I installed it when playing on cd the subs would only play. If the radio was on the speakers would then play. So I called the help line and they said i need to bypass the factory amp. This is a leased car so I don't want to be cutting wires up. Does anyone make a harness to do this. Thanks for your help.
To bypass the amp you would have to run speaker wire directly from your new headunit to the appropriate speakers. A headunit won't be able to power the sub by itself, however.
Send me an email ill forward the diagram crutchfield sent me preatty much you have to cyt the plug off the stock amp and splice the wires not hard just the amps a bitch to get out clmbngfrk18@hotmail.com
Edit: you dont have to go from the HU you can just take the in on the amp and connect to the out
Well I did it and it works great. Thanks alot. The people at Crutchfield know jack **** and want you to cut up your car. Losers.
I hooked up my subs using the rear 6x9 adaptor thingys. I get bass from all 3 of them...and nothing had to be cut. But I might use my Pioneer actual headunit to make everything neater.
i dont' have a pioneer system in mine but crutchfield told me if i did that i would have to run new speaker wires to every speaker from my aftermarket headunit and that i would lose the subwoofer
ok so what this thread is telling me is that even though i have the pioneer system i don't have to bypass the amp at all? Just buy my aftermarket headunit (so i can play my ipod) from crutchfield, use the stuff they send and make sure that the harness is hooked up correctly? because if that is the case i'm gonna make sweet sweet love to every single one of you guys.
thanx
so where is this pre amp at i have all fusion speakers and amps and a kenwood double din nav .and every once in awhile i hear a crackling noise regardless if the amps are hooked up. im assumming the preamp is doing this so i am gonna bypass it completly. any body else have this problem ? also if i touch the speaker wires together i get a pop noise even thou theres no after market amps hooked up
how
Hi, can you help me do this? i'm planning to put mono sub to my pioneer HU too myself and i have no idea about it. I mean, wiring diagram
k well if u want to keep your speakers and sub witht the fatory deck just by the cheap harness but since the amp is 224 watts and your deck will be pushing out 50 watts per speaker and sub you will need to use rca cables to keep a low sigle so that your speakers wont blow so on the harness on the speakers u will want to splice in the rca caple to the spkear wires then hook them up to the head unit
k so if you have any other harness then metra you will need to re-pin it, but first to by passs the amp on the harness you bought you want to splice in rca caples to the speaker wires on the harness the red rca is always right and the white one is left, when you cut the rca the wire that is inslated is postive and the wire not is negetive so, front left speaker you would take the white rca and put the negetive wire on front left negetvie and the postive wire to the left front positvie once your four rca cables are spliced in hook it up to the deck but dont run thos wires to the harnes all you will be is running is acc,ground,power and the orange wire im pretty sure forget about the speaker wires.
if your have any questions reply i also have pictures of what i did and my car is an 06 ss/sc but if your car is an 07 ss with pioneer you will need a 150 doller harness
importkiller
09-30-2015 07:18 PM
