Can a different 10 inch sub be put in the pioneer factory box?
hey i was just wondering if i could put like a 10 inch rockford inside the pioneer factory sub? or any 10 inch sub for that matter and run a amp to it just using that box. thanks guys for ur input!
You could use the box but the mounting depth isn't very deep. You could always use Rings of MDF as spacers to make the box a bit deeper if you are set on using that box. I have no idea what the air space is in there but it doesn't look like too much so that is another thing to worry about.
Figure out the mounting depth and the air volume in there and then pick a sub accordingly. When picking your sub, don't forget about the air displace by the sub too when you are calculating the volume.
you could go with a better quality low excursion sub, I'm pretty sure the box is sealed, so just look for something that is good in a box under 1cu ft sealed, and dual voice coil, not sure if's 2 or 4 ohm though.
I think read somewhere that the factory box is .67 cubic feet or really close to that. It was the same size my Rockford Punch HX2's required. I doubt that it would fit though. Those HX2's have a huge basket and magnet.
hell ya i love my 8" HX2
I added an infinity sub to mine since I had problems with the stock sub and didnt want to put a larger box in because I need my trunk space. I filled the box with polyfill doesnt sound bad at all its a lot better than it was stock.
Heres the picture
Heres the picture
I have an MTX Thunder 6000 10" sub that was going to try and put in the stock box. I dont know if it will fit but if it dose I will post a few pics adn a how to.
Going to try it in about 10 days when I get home.
Later
Later
were you able to fit the stock grill? if so i would grill that baby up
