Can you add a second stock sub?
Old 06-09-2009, 11:40 AM
  #51
Militant_Jurist's Avatar
Originally Posted by hailcesar75
subd
Old 06-09-2009, 12:08 PM
  #52
ctcsoccer7's Avatar
ok pulled my car apart and found that the RAP wire in my 2006 LT is a thicker yellow going into the passenger and driver kick panel. Also found that you must have power windows/doors for this wire to be here. The wire will be thicker than all the rest of them and will almost look faded, (kinda whiteish). The easiest door boot was the passneger one.
Old 06-09-2009, 12:18 PM
  #53
Thanks for getting that info!
So I can just splice the power from the amp into the RAP, ground the amp separately, and then use a LOC from the input line to Sub1 over to input on Sub2. I'll wire the subs down to 4 ohm each by the method we discussed. Will wiring into the RAP mean that I won't have to worry about wiring the remote turn-on?
Would you say that $165 would be a good deal for a new Kicker 08ZX400.1? I found it on Amazon.
Old 06-09-2009, 12:28 PM
  #54
cgrammer's Avatar
Originally Posted by Militant_Jurist
Sub'd means subscribed. He just typed in the thread so it's saved for future reference.
Noob... I was one, too.
Old 06-09-2009, 12:32 PM
  #55
Haha that makes sense now. I was actually quite surprised when I was unable to find this kind of information just through searching the web. Hopefully my questions and the great answers I've received so far will also be able to help others.
Old 06-09-2009, 06:26 PM
  #56
ctcsoccer7's Avatar
dont wire power into the RAP...wire the amp turn_on into that wire....Power is in the trunk under the mat ,at the battery. You have 3 power wires 12volts constant, Ground(negative) and amp turn on(RAP) and the LOC for rcas!
I think that price is kinda high! i would say dont jump over 100!
Old 06-09-2009, 06:35 PM
  #57
hailcesar75's Avatar
i was one too and didnt know what the hell it meant
Old 06-09-2009, 11:16 PM
  #58
Any suggestions for where to get a new one? Crutchfield has it listed for $299, Amazon is at about $165, and I've only seen a used one on ebay for under 100, but it didn't have the remote control wire. Is that a big deal? Could I rig up a replacement remote control?
Old 06-09-2009, 11:36 PM
  #59
ctcsoccer7's Avatar
i wouldnt really be worried about it......worst case i could sell you on for like 5 buck plus shipping, i think i have like 2 or 3 in my tool box.
Old 06-10-2009, 12:55 AM
  #60
EmperorJJ1's Avatar
ya the remote bass knob needs to be thrown away anyway. and i dont know about u but 165 for 400w rms, new, kicker... sounds like a damn good deal
So if I have it wired to 2 subs at 2 ohms, would I be fine? Or would I also need to wire it down to 4 ohms?
i knwo im just going to confuse the **** out of u and ruin this whole conversation but stock subs are dual 2 ohm. so think of each speaker as 2. with a total of 2 subs you would have 4 voice coils.
  #61
Yeah, I'm kind of leaning towards getting it new, because who knows what this ebay guy did when taking it out of his vehicle. Plus, I'd be getting a warranty with a new one. I'm going to think about it tonight, but if the Kicker will work great with my plan, I'm leaning toward just going new, and having less risk attached.
Haha yup, that just confused me pretty well. If it's a dual 2 ohm, and I need to wire down to 4 ohm to keep from blowing the subs, what does this mean for me?
Or is that the reason why there are two pairs of (+) and (-) on each sub? From what I understand, the diagram I posted was specific for a pair of DVC subs.
Old 06-10-2009, 12:30 PM
  #62
ctcsoccer7's Avatar
so your not confused, go with your diagram, it will work for what your doing but just think of it as running it to the amp not from sub to sub.
he mean + - , + -, + -, + - but depending on how you wire it you can get 4ohms or 1ohm, just go with your diagram. it will work
Old 06-10-2009, 12:32 PM
  #63
Ok, so I'll be taking the input off of the stock sub1, using a LOC to connect the input to the amp. Then I'll be running each sub to the amp, wiring each down to 4 ohm.
Old 06-10-2009, 04:45 PM
  #64
ctcsoccer7's Avatar
yes but you dont have to take the input off, just wire into it. leave it plugged in!
Old 06-10-2009, 05:49 PM
  #65
How does sub1 get run off of the Kicker then?
Old 06-10-2009, 05:52 PM
  #66
camshaft343's Avatar
I just tried to mirror image fit another one. It DOES NOT FIT.
Old 06-10-2009, 05:57 PM
  #67
ctcsoccer7's Avatar
could have told you that!.....you would need to build a custom box
Old 06-10-2009, 05:59 PM
  #68
ya...Harrison and I looked for the this thread and couldn't find it.
Old 06-10-2009, 06:01 PM
  #69
ctcsoccer7's Avatar
ive seen it done on my boys car , he just took a factory SS box and then went to town on it with fiber glass! turned out good!
Old 06-10-2009, 06:03 PM
  #70
oh cool. I don't have fiber glass tools or material so I'll just buy a dual 8" box
Old 06-10-2009, 06:07 PM
  #71
ctcsoccer7's Avatar
also try ZENCLOSURES.com he makes car specific boxes you just have to tell him for how many subs/size. On the site its for 2 12s for the cobalt.
Old 06-10-2009, 06:08 PM
  #72
I'll have to look into that, either a new box or retro-fitting the stock.
I suppose I'm a bit confused now about how the amp and sub1 will be connected? Sub2 wiring is pretty clear, but it sounds like sub1 will not be actually run off of the Kicker.
Old 06-10-2009, 06:10 PM
  #73
ctcsoccer7's Avatar
huh? where did you get lost? of course its gonna hook up to the amp!
Old 06-10-2009, 06:27 PM
  #74
So the stock sub1 will be hooked up to both the new amp and the stock amp?
I was envisioning a clean and simple setup such as this:
with the amp being connected to a pair of wires with a LOC between the stock amp and new amp.
Oh, except that I remember you said each sub would be wired to the amp directly, instead of sub2 to sub1.
Last edited by Militant_Jurist; 06-10-2009 at 06:27 PM. Reason: Automerged Doublepost
Old 06-10-2009, 06:34 PM
  #75
ctcsoccer7's Avatar
if you take the bottom sub and go to the amp its the same thing . dont loop the subs, just take both of them and go to the amp. you will still get the same power and at the amp the ohms will be 2. ITS the same just dont run the bottom sub to the other sub , run it to the amp
Quick Reply: Can you add a second stock sub?
