Canadian auto headlights bypass solution!!!
A relay can be added to this so that a switch is not even needed and turning the headlights one notch to the parking lamp position will reactivate the dash lights (like, gasp... a normal car!). I'm trying to figure out how to wire that up.
My reason for wiring it up like this... if this sensor supposedly controls the dash lights, then there's no reason to not have it connected to the running lamps like in a normal vehicle. Turn the switch one notch, ambers, tails, and dash comes on. Second notch for headlights. Of course you could still have a switch in this if, for some reason, you want all your lights on but no dash lights at night. Wiring it like this effectively nullifies your sensor.
If your suggestion works this one should as well. If the light sensor provides resistance and that's what activates the dash lights and auto lights, my wiring scheme also includes said resistor. When you have not manually turned your headlight switch to the parking lamp notch, the light system will work as it does in a factory car. In theory doing it this way simply adds an automatic way to re-add the full 12V+ so the car again thinks it's night time. You're right, though, it's really not that hard to flip a switch.
I do understand what you are trying to say.....in theory your way should work, but when the resistor is inline with the factory sensor the park lights or running lights as you call them will not turn on with the 1 click on the headlamp switch......therefore, you cant use that as a relay trigger.....if you are talking about the daytime running lamps then yes you can use that wire because they come on as soon as you put the car in gear.......BUT that would defeat the whole system because that would inturn allow the headlights to turn back on along with the dash lights......i hate this new car **** cause its all computer controlled and you can only fool it so much......i like my 1980 ford 4x4 cause its sooooo straight forward......LOL...Later
Well if no one has figured you how to bypass the automatic headlamps on the canadian model cobalts.....this is how you do it...........
Go to the source or whatever store you chose to purchase resistors......you will need a 500ohm or 1000 ohm (1Kohm) resistor and a switch of some sort.......take the defrost cover off of the dash and disconnect the light sensor......now take the 2 wires going into the sensor and tap into them with either t-taps or strip the wire back and solder a pigtail wire onto them.....do not cut the wires to do this...connect one side of the resistor to one of the sensor wires and the other side of the resistor needs to go to a switch(i will explain later)...the other side of the switch goes to the second wire from the sensor....so now you have a resistor wired in parallel with the sensor and you can turn it on and off with the switch.....the reason for the switch is that at night time you will not have dash lights if you just put the resistor in so you can turn that option back on if you so choose but the headlights will come on as well.......this you cant get around, the dash lights will not work if the car thinks its daylight no matter if you manually turn the headlights on or not....Any questions feel free to PM me and i will explain it differently if you need me too.....will also try to post a drawing to make it clearer......Later
http://g.imagehost.org/download/0359/headlight_bypass
thanks! sorry it took so long to try
Auto Headlights in Canada
I have a brand new 2009 cobalt from alberta canada i pulled the drl 10 amp fuse and done . No auto head lights. I saw a post of some crazy do hickie set up. Not needed
First impressions are important......first posts i guess are not......ya gotta read before you pipe up bud.
#37
#39
unless you have a Canadian car (RPO: 'Z49' would be on your options sticker), you shouldn't need it, as the Canadian cars actually have the "autolights off" feature disabled - they are wired/programed differently.
But if you need to do this, the link isn't actually needed, it's spelt out in the first post;
I edited the quote, and highlighted in bold/red the part that makes Canadian cars (unfortunately) unique.
This was the first modification I did to my car, instead of cutting and splicing Imade a complete pigtail that had a switched relay/bypass, and just pluged it inbetween the dalight sensor, and the sensor plug - it works flawless for me.
I used male and female plug ends from early 1990's GM seatbelt warning connectors to make my setup.
Well if no one has figured you how to bypass the automatic headlamps on the canadian model cobalts, this is how you do it:
Now you have a resistor wired in parallel with the sensor and you can turn it on and off with the switch.
The reason for the switch is that at night time you will not have dash lights if you just put the resistor in so you can turn that option back on if you so choose but the headlights will come on as well.
This you cant get around, the dash lights will not work if the car thinks its daylight no matter if you manually turn the headlights on or not.
- Go to the source or whatever store you chose to purchase resistors
- purchase a 500ohm or 1000 ohm (1Kohm) resistor and a switch of some sort
- take the defrost cover off of the dash and disconnect the light sensor
- now take the 2 wires going into the sensor and tap into them with either t-taps or strip the wire back and solder a pigtail wire onto them do not cut the wires to do this;
- connect one side of the resistor to one of the sensor wires and the other side of the resistor needs to go to a switch(i will explain later)
- The other side of the switch goes to the second wire from the sensor
#40
So to revive an old thread. This worked for me. While my installer was wiring up the sunroof module to my alarm, he charged me $20 to do this. It was super quick since he has everything right there. Switch installed right next to trunk release button. He wired up two 350 ohm resistors and it works prefect.
I wanted to do this because I had remote start alarm installed, and that turns on HID's because of auto headlight feature, then it cycles them when the remote start turns over the engine. That's too many cycles for me.
#41
#42
I'm not sure what you're saying;
the Canadian auto lights cannot be turned off;
they dim the gauges (most notable on RPD equipped cars, and on the radio) when the daylight sensor thinks it's dark out (low light situations, or near dusk/dawn) it dims the dash lights, making the radio & RPD nearly unreadable.
This in-line resistor tricks the bcm(?) into thinking that it's light out so that dash lights/radio/RPD get full illumination.
It appears as though I mis spoke in my quoted post;
The dash lights will always work, and even with the bypass turned on you can still manually turn on dash lights;
The key in this modification is always being able to easily read the radio & RPD.
#43
I read 2 pages of posts in bold text saying they will not work... Let's only post things we know are true instead of guessing.. Not the end of world but I kinda wasted $10 on switch n drilled some low unvisible plastic for the switch, just would have perferd not to is all.
I will check to see tonight if the dash light dimming or whatever are affected by by-passing the sensor.. However I really doubt the dash lights need to be dimmed at night, they look fine to me.
I haven't turned the resistor off since I out it in, I have had no issues at all. I have a sedan, no rpd, it seems like your saying the sensor dims the dash lights when it's light out, which makes perfect sense, your complaint is that they don't turn bright soon enough. A resistor with no switch accomplishes this by just using the combination switch as regular switch where auto is off.
THE SWITCH IS NOT NEEDED! LOL
#44
if it was absolutely required the cars wouldn't have been built that way, however if yours is a Canadian 'Z49' car, the daylight sensor dims radio, and RPD to nearly unreadable backlighting levels at an annoying occurance;
American destined (non'Z49' cars) can disable autolights if this happens;
The only time Canadian cars can disable autolights, is when they're parked with the e-brake up - as soon as the e-brake is released the autolights re-engage.
I use my switched resistor every morning, and have for nearly five years...
How long have you been here that you're telling us this is an unwarranted mod? ~ Oh look, you haven't been here even a year...
How about you quit trying to reinvent the wheel(?) - this thread has been invaluable to many people for YEARS prior to your signing up.
#46
Why would it matter if I only been here less then a year, I purchased my cobalt inside the year n I don't troll forums for cars I dont have lol. I've been working on cars for 15 years, licensed tech, I understand how the system works - I knew I wouldn't need.
Tom77 is right, all you really need to do is unplug the sensor, thereby giving you infinite resistance which bypasses the sensor as the sensor resistance goes up when it sees sun light. All you want to do is trick the car into thinking it's daylight all the time.
Are you somehow saying you want the automated dash lights without the headlights doing the same? I just don't understand, if the autolights dim the dash lights why not just control them manual all the time, your saying your to lazy to flick a switch to control the dash lights but your willing to flick a switch every morning lmao this thread is a fail, but that's what I get for taking the easy way out n not figuring it out myself, laziness never pays!
Lastly maybe if I had have come to the forum sooner all the ppl who wasted their time wouldn't have lmao
#47
I'll ad before you spout off about me being a mechanic or whatever .. I work at Honda n can't get wiring diagrams for other makes otherwise I would have just used them
I dunno what it is with this site, everyone on here knows everything about a cobalt... Lmao
#48
Without this in line resistor switch, I couldn't read my RPD, or radio at an annoying rate.
The only way that I can describe it for people who haven't done this mod, is when parked in low light situations, with the ebrake down, the RPD & radio dim & the exterior lights all go on - this is fine except often in this situation, you cannot read the RPD or the radio (the radio is probably 20% brighter than the RPD);
If in that situation, you pull up your ebrake, and rotate your headlight switch to disable the autolights, then the RPD & radio once again become readable;
As soon as you release the e-brake, the autolights engage, and you cannot read the RPD again.
With American (cars not showing hte RPO (regular production order) code of 'Z49', the autlights disable feature works regaurdless as to if the car is stopped with the ebrake up, or the car is moving with the ebrake down - Canadian cars don't - the autolights override your ability to control "dash" (including RPD & radio) backlighting ~ but at the same time do so, in accordance with Canadian daytime running lights laws.
With this switch, I can control the diming of the RPD & radio like I couldn't before - and it effectively allows me to disable autolights like american cars can right out of the box...
I really couldn't care less where you work, if you feel this is an unwarranted modification, that's fine - you've said your part - please drop it now, because not everyone shares your opinion - just like not everyone is going to share my opinion.
As I had understood it, you cannot simply unplug the daylight moniter - the BCM looks for a signal, resisted or staright through, in a similar way how when these cars were new people were trying to find other ways to get around this Z49-only feature by unplugging things...
To myself, and others to whome I have spoken, this is a very handy thread.
#49
You must not be reading n understanding what I'm saying.
I understand what the mod does, it does work, what I said was you don't need a switch at all, you don't even need the resistor..... All you have to do unplug the sensor, as the dash lights do still work, which you suggested they wouldn't.
Thanks for coming out, End of story.
