cant adjust 3rd gens?
My third gens are fine thus far, and have been on my car around a year, and went through last winter to boot. I don't know if the stock lens will fit perfectly on the projector housing, but the lines on the stock lens that normally separate the headlight from the signal light might get in the way of the projector beam.
i have a set of 3rd gen projector headlights, and i recently took them out cuz i cant get them adjusted from where they are pointed... which is about 5 feet in front of me...
and you have to keep taking the light out to adjust them and i did not notice any changes in the placement of the light so i took them out all together... anyone know anything about this?
and also... is it possible to put the actual clear lens off a housing from some stockers and make them fit on the 3rd gens? i havent looked to see if any of the clips are the same or anything.
any help would be awsome!!!
thanks
-Casey
thanks
-Casey
what bolts do you turn? i heard they're near the bottom of the lights but when i open the hood everythingis so crammed together and can't really see anything obvious. do i need to take the headlights out again? what do i do to fix this? where are the bolts? it'd be appriciated.
The Rookie24
09-20-2015 04:33 PM
