Car stays on w/o key after interceptor...
Old 07-20-2011, 03:50 PM
07BoostedG5's Avatar
If you have the red jumper still on thats why, pull it out and your all set!
Old 07-20-2011, 03:54 PM
Tstonee's Avatar
haha I think so.. after actually doing some thorough research and reading everything. Be back in a little bit and i'll letcha guys know what happens! Thanks guys!
Old 07-20-2011, 04:56 PM
Adamakalin's Avatar
When I remove the jumper, do I remove JUST the red part? or the red AND the white part?
Old 07-20-2011, 05:13 PM
just the tiny red clip, but you have then use the harness that came with to wire in a remote power source, else it will never turn on.
Old 07-20-2011, 05:21 PM
Dayta's Avatar
supercharger timer ftw
Old 07-21-2011, 12:31 AM
Tstonee's Avatar
Good news! Got more problems!
:cuss ing:
If I plug in my interceptor, it powers my whole car? Like having my interceptor hooked up is like having my key to turned to the accesories.. But I don't need a key to do it......
Nowwww my ******* wideband......
All hooked up.. But when I turn my car on, the lights are super dimmed annnnnd it's not reading.. like it'll go 11.1 22.2 33.3 etc all the way to 99.9, and then read --.- for a little bit, and then repeat the numbers and so on...
I
hate
my
life
Old 07-21-2011, 12:40 AM
SunburstSS's Avatar
dude take the jumper off the back of the interceptor and run the red wire to the power windows fuse and thats it ...it will power on with the car and shut off with the car ! /// this will solve that problem
Old 07-21-2011, 12:41 AM
SunburstSS's Avatar
As for the wideband you can use the same power wire your using for the interceptor to power the wideband as long as its a 12 gauge or thicker with a inline fuse...black is ground and the other two leave alone...done deal !
Old 07-21-2011, 01:30 AM
Tstonee's Avatar
Jumper is off, calm yourself. and power windows fuse in the fuse box i'm assuming?
Old 07-21-2011, 02:26 PM
Tstonee's Avatar
Old 07-21-2011, 02:53 PM
  #36
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by BPacak
with the ss/sc you have to run a power wire.
This.
I used an empty slot on my fuse panel. No running it off the boost gauge, sunroof fuse, etc....
Old 07-21-2011, 02:58 PM
  #37
Tstonee's Avatar
This.
I'm sorry but can you PLEASEEE take a picture of where you ran your power wire for either gauge?
Old 07-21-2011, 05:58 PM
  #38
Oh how it feels to be a
balt_ls's Avatar
I mean jesus just find a fuse in the fuse box that shuts off when you shut the car off. It can't be that damn difficult.
Old 07-21-2011, 07:32 PM
  #39
Tstonee's Avatar
but it is
Old 07-21-2011, 08:00 PM
  #40
SunburstSS's Avatar
Lol I was calm dude I don't know whatcha talk ! If anything ur heated hahah if u don't get an answer by tomorrow I'll take a pic for ya tomorrow as I'm off and I'm at the airport now
Old 07-21-2011, 08:07 PM
  #41
Tstonee's Avatar
Thanks man. Idk wtf the problem is... so god damn annoying and i'd hate to have to pay someone to wire a ******* gauge..
Old 07-22-2011, 02:23 AM
  #42
Switt23's Avatar
From the sounds of it, the wire you tapped for power in the radio harness it the RAP (accessory power for 10-15 seconds once the key is out or door is opened). This wire picks up signal from your ignition. Not sure if power is somehow being fed from the obd2 through the gauge to that ignition wire... Hence the accessory power on with the gauge.
Change the power source. If you pull the panel open on the passenger side of the center console, find the sun roof or power window fuse. (there is a diagram on the back of the panel). If you got to walmart you can by a fuse tap, it's got connections like a fuse, 2 slits for mini fuses, and 1 lead wire. Looks like this...
Again find the sub roof or window fuse and pull it out. Look to see the size, should be a 15A or a 20A. Match that in the fuse tap and then plug the fuse tap back in. Connect the power wire on the gauge to the wire on the fuse tap and try that out...
Hopefully this helps.
Old 07-22-2011, 02:25 AM
  #43
Switt23's Avatar
Sorry if that's hard to read, my iPhone has the grammer of a 3rd grader.
Old 07-22-2011, 02:42 AM
  #44
SS_NH's Avatar
interceptor to obd2, remove red jumper, ignore white and green wires, run red wire to pink wire on boost gauge.
whatever fuse you have it ran to, it must still be drawing power once the car is turned off.
pink wire is the best way I've seen it.
however, I know nothing about widebands and I wish you the best of luck.
Old 07-22-2011, 11:02 AM
  #45
Tstonee's Avatar
Thank you.
This was the kind of answer I was looking for.
Old 07-23-2011, 09:53 AM
  #46
SS_NH's Avatar
Originally Posted by Tstonee
Thank you.
no problem man, hope you figure it out!
Old 09-27-2011, 09:00 AM
  #47
PikerAA's Avatar
I own a 2005 SS,
Unfortunately, this is what I have done but still I am having the same issues as OP. My car stays on for about 10 seconds before shutting down.
What I did:
1: Installed dual gauges with red wires tapped into pink stock boost guage wire (White and Green go to nothing)
2: Plugged in OBD2 port, without key in, and the car started? WTF?
3: Realized I needed to remove jumpers for 2005 Cobalt SS's, did that.
4: Car still remains on when key is removed, "POWER STEERING" comes up on dash when I start car and the gauges will not shut off.
Thoughts?
Would running to the fuse box really make any difference? Isn't the pink stock boost gauge wire one that shuts off with the car? Did starting the gauges with jumper connect initially possible mess up my gauges?
Thanks for any help. Hopfully OP gets his answer too.
-Pike
Old 01-12-2012, 10:23 PM
  #48
SA420's Avatar
That is awesome, gone in 60 seconds, lol.
Turbo Johnny
02-21-2019 09:41 AM
red9
10-04-2017 02:23 AM
chefhhr
10-26-2015 10:36 PM
Gugi96
09-15-2015 12:24 AM
jthwjde
09-07-2015 09:24 AM
Quick Reply: Car stays on w/o key after interceptor...
