Cobalt and Equinox CD player
The radios are VIN specific.
They will line up harness wise but will not just swap over.
You have to take it to GM and have them reflash it and even then there a 50/50 chance of it working.
I only know of one person that got it to work correctly but he knew a guy at GM so...
problem your going to run into is diffrent harnesses
the equinox uses the metra 2003 and the cobalt uses the 2103
on thing i just thought of thou you could get the cobalt harness and the eq harness and wire it up and it might work. only thing is i dont know if the gm lan is on them and im assuming its necessary for the stock radio to work
and im wrong again the eq and the cobalt are listed by metra as the same harness
