Constand 12V?
Constand 12V?
So I just finished installing my pioneer XM sat receiver, the only problem i have it that it has a wire that needs a 12v Constant source, and im not really in the mood to splice into wires and i dont want to have to run another wire so the 12v goes to the battery.
Is there a constant source in the fuse panel? and if so what fuses? ... may need to go find an add-a-fuse, dont know where locally though...
check ur cigerette lighter fuse in the panel. u dont need a add a fuse. just strip about a inch of insulation off the wire and wrap it around one the leg of the fuse and put the fuse back into its slot.
soundjunky
08-28-2015 03:24 PM
Electrical: 12 volt power tap and grounding for accessories
Iroc
How to Guide
36
03-07-2012 01:14 AM
KeystoneSC
How to Guide
35
05-20-2011 02:53 PM
