DDM replacement bulb question
I got my 8k bulb replacement in..but these bulbs don't come with a plug. The side that on the original bulbs had a plug don't have that plug but 2 individual 'prongs' is the only way I can think of describing them. What do I do with these haha
yeah more or less like that except mine are longer. That picture is how mine came, I plugged that plug in the picture in and had one leftover. I tried them both in each hole and did every combo there was and nothing.
yeah if youve got bulbs that have those attached to the bulb you just chuck those, Ive got a whole pile of those things I take em off every set of H1s I use. But if the OP only has metal terminals on his bulbs hes gonna need to swap the plastic AMP connector over. If thats the case this is just one more reason why DDM sucks.
If all you're replacing is a bad hid bulb you don't need those wires, they power the ballast. Just replace the bulb. If this is truly confusing I must he missing something. Remove old bulb from light, unplug old bulb from ballast. New Bulb goes in light. Two plastic connectors plug into the matching connectors on the ballast. Done. Literally as easy as replacing a light bulb.
DANRICKARD
10-01-2015 12:08 AM
