Depo 4th Gen LED wiring
Greetings,
I recently purchased 4th Gen headlights and put in some LED switchbacks. I thought I could live with the hyperflash but its starting to become annoying. That being said I got some resistors to fix that.
A have a few questions
1) How hot to the resistors get? I want to wire them into the harness of the headlight instead of hacking to the OEM harness.
2) Are they hot enough to melt the plastic if I do decide to wire them inline of the headlight harness?
3) which one of the 3 wires would I tap into for the signal
Thanks in advance!
Thanks in advance!
They didn't gave instructions? It should be one ground and the other to the one that activates the turn signal. And the get hot... Really hot, they burnt through the carpet in the trunk (had them for LED taillights) is the same concept for the front if I'm not mistaken, just find a place that does not touch anything that can burn or melt.
