Diagnosing Clutch Sensor Problem, ran into unexpected issue, info needed
Ok guys, its been a while sense Ive been here, diddnt even get to post pics of the balt before I dissapeared. Anyways Ive been having clutch sensor issues, Throws P0808 clutch position sensor high voltage, then that triggers an onslaught of codes to follow includeing P0010 Camshaft position sensor. Car runs fine when it decides to start. When it doesnt start, all the lights radio etc. Comes on. So after some research I decided to find the switch and check it out. well when I tore into it I diddnt see the switch where its suppost to be located, could have missed it but I did see somthing else. A black box, says Jetkit on it. Is this a performance module, I beat google like a dead horse and got no results, got no results from the sight here. Only info I could find on the box itself was Jetkit 88186086, JLSOL-000261 im assuming one of theses is the part number. Couldnt find anything on them, not even a retailer? I snapped a pic to upload as well.
any input on the clutch sensor issue or this possible performance module would be greatly appreciated.
ok, figured out what this thing was. Power steering modulator for electric power steering. Things are getting to high tech for me lol Any info on the location of the clutch sensor would be appreciated.
Don't quote me on this but I believe the switch is located right behind the clutch peddle. It's worth a shot to look and see. Maybe someone can come by and confirm this or not.
