Disable Auto Lights
yeah ballasts were screwed due to my drl im just gonna pull the fuse during the day
i just orded a new kit from vvme so we will see if these last
Last edited by stoon_cobalt_colby; 03-10-2010 at 01:27 PM. Reason: Automerged Doublepost
But everything worked fine... so I am asking what the fuse actually did?
Interested in the auto on/off function also... I've ordered a set of 6K HIDs and I know when I install them the DRL fuse MUST be taking out, BUT I've already tried this when I take the fuse out my auto lights still come on during the day. And I don't want my HIDs running during the day for no reason or keep turning them off when ever I turn my car on.. It's hot in FL I don't need any extra heat in or on my headlight lens's lol
DRL makes your low beams to come on during the day. If you install a relay harness (which is recommended with hids) you do NOT need to remove the DRL fuse. As for the auto on/off function there's a thread on how to install a resistor so the sensor always think its day... You then need to turn on your headlights manually!
z28addiction
09-28-2015 12:03 AM
