Do I need a second battery?
Old 05-22-2009, 02:57 AM
iboost's Avatar
Ok, so this is what I'm going to be installing into my car:
Pioneer AVH-P4100DVD Receiver
Pioneer Premier TS-SW1001S4 Shallow Mount Subwoofer
Pioneer GM-D7400M 800 Watt Mono-Channel Amp
Slim PS2
Is that too much to run off my battery? If I should get another one, does anyone know how to run everything for a second battery? I don't know very much about the whole car audio. Any help would be great. Thanks.
Old 05-22-2009, 02:59 AM
raptors_67's Avatar
No.... if for some some reason someone convinces you otherwise an isolator is a must.
Old 05-22-2009, 05:48 AM
Spun's Avatar
Just upgrade the battery in your car rather than adding a second one.
If you look in the stickies at the top of this section you will find some usefull Battery info.
And you can run the batteries parallel but unless you really know what your doing, and can fix "on the fly" then I would go with the isolator as well if you do chose to go the second battery route.
However your not running alot of power sucking equipment so I wouldn't stress about a second battery.
One more thing, Caps (compasitors) are a waste of time/money IMO so don't waste either on one
Old 05-22-2009, 05:53 AM
silver187666's Avatar
if you do need a new batter just wire it to the old on, thats how i do it on the boat
Old 05-22-2009, 08:56 AM
iboost's Avatar
How many amps is the Stock Alternator in these cars? How do you know how many amps an 800 watt amplifier is drawing?
*bump*
Old 05-22-2009, 12:19 PM
ctcsoccer7's Avatar
ok for one you would need an isolator , cant just loop a battery to another one! and for this setup no you would not need another battery, its not pulling enough current to make it an issue to even look at.
*bump*
you look at the fuse on the amp to find out how many amps its pulling. Like if it had 2 20 amp fuses , it would be pulling 40 amps of current.
upgrading the battery is one thing you can do a red or yellow top OPTIMA battery would be one i would do, but to say a CAP is a waste of time would be incorrect. A cap is good because it keeps the pull of the car audio system off of the stock alternator, extending the life of that alternator.
Old 05-23-2009, 01:28 AM
brickloaf's Avatar
caps are a waste
Old 05-23-2009, 02:28 AM
IBDRINKEN's Avatar
in my solstice i have running 2 kicker 10's infinity kappa perfects, 350.4 and a 1000.1 All I did was upgrade the batery to a red top and no problems
Old 05-23-2009, 03:55 AM
EmperorJJ1's Avatar
well first off that amp is 800w peak so 300 rms on a good day with good wire. secondly the full 300w rms will blow up that sub so you might as well bump that number right on down. Power inverter and PS2 will soak some juice but not enough to be concerned about so in my profession opinion you will be fine off the stock battery/alternator assuming they are both still good. Stock alt is 105a on the SS/SC no idea on the rest
oh and an isolator is for the most part retarded just like a capacitor yes it works yes it has a purpose but few people actually need it for what its ment to do. Most people just use them for the wrong reason and get pissed they don't "work" well
Old 05-23-2009, 10:48 AM
ctcsoccer7's Avatar
Originally Posted by brickloaf
caps are a waste
i can prove other wise! but to each his own!
Old 05-23-2009, 10:50 AM
slowswap's Avatar
Caps are a waste. Upgrade the big 3.
Old 05-23-2009, 10:52 AM
ctcsoccer7's Avatar
oh and an isolator is for the most part retarded just like a capacitor yes it works yes it has a purpose but few people actually need it for what its ment to do. Most people just use them for the wrong reason and get pissed they don't "work" well[/QUOTE]
im confused how can you be retarded , and work fine and serve a purpose? as i stated above for what he is using he wouldnt need either a CAP or an isolator, there isnt enough current draw on that amp for it to be an issue! i didnt just start doing car audio yesterday !
Old 05-23-2009, 11:10 AM
EmperorJJ1's Avatar
yes they are useful and have a purpose but they don't need to be and shouldn't be used for any and every dual battery setup out there.
Old 05-23-2009, 11:44 AM
brickloaf's Avatar
sooo if my amp is suppose to be drawing around 110 amps where does that leave me?
Old 05-23-2009, 08:52 PM
ctcsoccer7's Avatar
never said they should, i was just stating the fact that they do serve a purpose, and are not useless.
Old 05-23-2009, 11:51 PM
EmperorJJ1's Avatar
did you even read my post?
"oh and an isolator is for the most part retarded just like a capacitor yes it works yes it has a purpose but few people actually need it for what its ment to do. Most people just use them for the wrong reason and get pissed they don't "work" well"
fucked. i bet that amp can and will draw more then that before clipping. ultimately the game of playing keep up alternator amperage with amplifier amperage is a loosing battle. i mean look at me my electrical is rock solid but the sundown amp had a fuse rating of 300a, and the fosgate im getting soon has a fuse rating of 500a. yet my alt is a 200a
Old 05-24-2009, 04:38 PM
Spun's Avatar
You haven't got that Fosgate Yet?
So what are you running right now?
I was reading a car audio mag today that tested the RF T2500.1
2540@1ohm @ 12.6volts
oh wait it gets better
3293@1ohm @ 14.4 volts
So taking that into account lets say for example the amp your getting does 4000@1ohm @12.6
That would put it close to 5000@1ohm @ 14.4 , right?
What kinda power is that thing going to crank out at 18 volts, Like 7-8k?
Your going have to tow a generator around behind you
Old 05-24-2009, 04:46 PM
EmperorJJ1's Avatar
nah soon thou. im running a t20001bd from the shop
and ya that gonna be some serious power my subs cant handle. who thinks an inverted cone is in my future?
Old 05-25-2009, 06:51 PM
brickloaf's Avatar
i think 2 s18x in a fat ported box are in your future
Old 05-25-2009, 08:09 PM
EmperorJJ1's Avatar
nah i dont have the room for 18s
Old 05-25-2009, 08:15 PM
brickloaf's Avatar
3 solo 12's are 7500 which is around your range at 18v
but im guessing you care more about sq than spl
Old 05-26-2009, 01:52 AM
EmperorJJ1's Avatar
ya im 99% sure ill never change and if i do ill keep the XXX's . So if anything 3 12s maybe? but id probably loose some of that low end so its probably not going to happen
Old 05-26-2009, 03:35 AM
Spun's Avatar
How about 1 15 and 2 10's
You know, for midbass
Old 05-26-2009, 04:02 AM
EmperorJJ1's Avatar
sounds good! ill get started right away. the XXX trifecta
Old 06-02-2009, 02:17 PM
brickloaf's Avatar
just throwing this out there, someone said the alts were only 105 amp...
i was looking at sheet that said all my cars features on it, and it said "125 amp generator"
maybe mines upgraded?
Quick Reply: Do I need a second battery?
