dual 12 inch sub boxes
I just got a dual 12in sub setup with the box, but cannot for the life of me get it in the trunk. the trunk opening inst big enough, and i couldnt get it in from the back seats. how am suppose to get them in there??
any help appericated
is it a q-logic box?? i bought one for my sisters LS and i had to put it in through the back seats W/O amp and subs installed. i think i had the openings for the subs facing down when i slid it in. it was tough, but i got it. once its in theres enough room to flip it back up and more it around. i was able to move it 360degrees once it was in there
its not a qlogic, its a sony box but the dimensions are
height: 16.1
width: 32
depth: 18
if that helps
update
i took out the subs and just tried to put the box in...no luck
the only thing i can see working is if i took the back seats out to put it in...
any other ideas?
height: 16.1
width: 32
depth: 18
if that helps
update
any other ideas?
i takes literally 5 seconds to tkae the back seats out
seriously. the top push to one side and pull up and the bottoms push down and towards the back of the car and theyll come out.
thats what i had to do to fit my l7 box
theres 2 bolts, then u have to wiggle them around to get the metal bar on the bottom over the plastic on the side of the car.
I made a custom enclosure, but had to cut it in 2 pieces to get it in. Then I just reassembled it in the trunk. Had to actually finish all the trim pieces in the trunk. I brought it in through gthe back seat.
youre mental... my box is 34 x 14 x 12... i know its not the same, but i literally had no problem through the rear trunk opening or the rear seats... remove the bottom of the seats, then the back seats flip down about another inch... itll be tight but it should fit with it up 16", but put in on the driver side back seat otherwise youll hit a bolt
too wide and too tall. stock opening with everything removed (i would know) is 30" wide up top (37" on the bottom) and 16" tall
If you remove the seats and mounting bracket there's a slim chance you can literally kick it in there but don't expect ur carpet to be intact when ur done
i installed a 13w7 with a subzero box in my old civic. had to pretty much gut the interior to get it in there. one plus to a tight fit is no one will be able to steal it easy. they may razor blade the surrounds though if they get frustrated.
z28addiction
09-28-2015 12:03 AM
