Dumb audio question
Dumb audio question
Alright so I am planning on installing a kenwood double din with nav and i know that i need the harness, antenna adapter, etc. I know a lot of guys on here used the gmos lan 04 harness to hook up their double dins. I am just wondering if this harness is really necessary if you dont have onstar? I have the pioneer system but i dont have onstar so i am wondering if I should go with the expensive harness?
I assume u've got an 07+ yea?
If you have an 07+ and want door chimes/clicker of turn signal/seat belt chime: Pac C2R-GM11
If you have an 07+ and don't care for all the above mentioned: Metra 70-2202
I personally love not having door chimes and all. a couple times girls sitting shotgun accused me of not using my signal to change lanes because they didn't hear a click. LOL.
For reference, I've included the wiring guide found on a sticky to back this up. Since you are Pioneer look at the US8 connections. The other radio listed is the other mainstream mp3 deck used in 07+'s.
Radio C1
Connector Part Information
• OEM: 12110206
• Service: See Catalog
• 24-Way F Micro-Pack 100 Series (L-BU)
Pin
Wire Color
Circuit No.
Function
A1
GY
118
Left Front Speaker Signal (-) (1) (U1C)
A1
D-GN
1947
Left Front Low Level Audio (-) (US8)
A2
TN
201
Left Front Speaker (+) (1) (U1C)
A2
TN
511
Left Front Low Level Audio Signal (US8)
A3
L-BU
115
Right Rear Speaker Signal (-) (U1C)
A3
TN
1946
Right Rear Low Level Audio (-) (US8)
A4
D-BU
46
Right Rear Speaker (+) (U1C)
A4
D-BU
546
Right Rear Low Level Audio Signal (US8)
A5
BN
199
Left Rear Speaker (+) (U1C)
A5
BN/WH
599
Left Rear Low Level Audio Signal (US8)
A6
YE
116
Left Rear Speaker Signal (-) (U1C)
A6
BN
1999
Left Rear Low Level Audio (-) (US8)
A7
L-GN
200
Right Front Speaker (+) (1) (U1C)
A7
L-GN/WH
512
Right Front Low Level Audio Signal (US8)
A8
D-GN
117
Right Front Speaker Signal (-) (1) (U1C)
A8
L-GN
1948
Right Front Low Level Audio (-) (US8)
A9
D-BU
1796
Steering Column Radio Control Signal (UK3)
A10
WH/BK
644
10-Volt Reference (US8)
A11
Not Used
A12
BK/WH
1051
Signal Ground
B1
RD/WH
1140
Battery Positive Voltage
B2
Not Used
B3
L-GN
1011
Remote Radio Control Signal (US8)
B4-B5
Not Used
B6
PK
314
Radio On Signal
B7-B8
Not Used
B9
D-GN
5060
Low Speed GMLAN Serial Data
B10-B12
Not Used
Radio C1
• OEM: 12110206
Pin
Wire Color
Circuit No.
Function
A1
GY
118
A1
D-GN
1947
A2
TN
201
A2
TN
511
A3
L-BU
115
A3
TN
1946
A4
D-BU
46
A4
D-BU
546
A5
BN
199
A5
BN/WH
599
A6
YE
116
A6
BN
1999
A7
L-GN
200
A7
L-GN/WH
512
A8
D-GN
117
A8
L-GN
1948
A9
D-BU
1796
A10
WH/BK
644
A11
Not Used
A12
BK/WH
1051
Signal Ground
B1
RD/WH
1140
B2
Not Used
B3
L-GN
1011
B4-B5
Not Used
B6
PK
314
Radio On Signal
B7-B8
Not Used
B9
D-GN
5060
B10-B12
Not Used
