Electrical Lighting Help
My Vac/Boost gauge has three wires that come out the back. One of them is the ground and the other two are for lights withing the gauge. There is a white wire that i coded silver in the Awesome picture and a Red one. The red wire illuminates parts of the gauge to be red and the white one illuminates things to be white. I was wondering if its possible to hook up the light to work with my parking light switch? Like The red lighting will only be one with my parking light (ambers) and the white one will turn on when my driving lights are on ( Night driving so the gauge is fully lighted.) Can anyone give me a good diagram on how to do this?
Wait so you want the option to light them up separately and control when they do and don't light up? If you want that, you need to wire it to a switch, and I have a how-to that includes how to do that...
Tap the red wire into the parking light wire and tap the white into the headlight low beam wire. That's the most direct way to do I would think. I don't know where said wires will be located in the cabin, but if you find them then I would do that, with proper fusing and such to protect the circuits.
I used to have LED's in my grille that I wired to the park lamps, I grounded to a bolt in the bay, and I just jammed the power wire into the fuse slot for the park lamps, had it for over a year no problems.
im not even sure how thats relevent to wiring up a gauge. but ill take ur comment and step it up a notch
i got a big ass banner that said **** wetbacks on one side and **** ******s on the other side put it on a big ass pole and drove around in the hood listening to racist ass redneck music and didn't get shot.... that doesn't make it a good idea thou does it?
i got a big ass banner that said **** wetbacks on one side and **** ******s on the other side put it on a big ass pole and drove around in the hood listening to racist ass wetback music and didn't get shot.... that doesn't make it a good idea thou does it?
Well it wasn't that tight of a fit, all I'm saying is that since the metal of the wire was touching the actual fuse it didn't do any actual harm, and it was LED lights so they basically run on nothing. And no problem, this is like the most harmless misunderstanding I've ever seen on this site.
z28addiction
09-28-2015 12:03 AM
