Factory Sub Question??
I know the factory sub is a dual voice coil. Now im wondering if it is a dual 4 or 2 ohm. The reason im asking is that I have a Dual 2 ohm sub and Im wanting too hook it up. Any advice????
Aight that sounds good. How did you get it out? I tried just the other day by pulling off the grille and when I tried getting the sub itself out it just kept on popping right back in the enclosure. I stopped messing with it because I didnt want to break nothing. LOL
There are 4 or 5 10 mm nuts that hold the enclosure in place.Once you remove them,the box will come out.Once you get the box out,theres a screw in the back of it that goes through the speaker magnet to hold it in place.Once you remove that screw in the back and the screws that hold on the grill,the speaker will come right out.
It dont weigh that much.If your not into bassy music,than take it out.I like music with alot of bass,so i wouldnt remove it.I replaced the sub with a jl sub,and it pounds.Its perfect for me,and i still have all my trunk space.
Share Jack, share
is there any way of making the stock sub louder??? or can i just buy a new 10" sub??? i have a memphis 10" right now but it prob wont fit in the box right??? can you adjust any gains in the stock amp??? let me know thanks b/c the stock radio seems to get to a point and dont get louder than it should prob so stock dont blow...
Whick JL did you replace it with? Did you have to make any adjustments to the enclosure?
anyone know the airspace on the box, or the RMS of the factory amp? air space matters when choosing an aftermarket speaker, and make sure to keep the vent on the sub clear or you will burn it up.
Hey, ok so... did you just keep everything else stock tho??? like did you add a different amp or deck or no??? b/c it seems like that stock pioneer should get louder but maybe not... is there any gain controls or anything on the stock amp??? so your saying you just took out pioneer amp and put the jl in w/ a little modifcation and it sounds much better? or a little better???
