Fail!! tried installing leds in hvac. please help
Old 10-29-2010, 01:01 AM
c4w18's Avatar
Originally Posted by 09xfebalt
I can BS I used 12 leds that DO NOT have any resitor can take pics if you like.
lol take a picture please cause i've never seen one...show me a single diode that works in a 12 volt application and i'll be impressed.....but if its 2-6 diodes strung together to one connection i'll just lol.
Old 10-29-2010, 07:15 AM
scottydoh's Avatar
show me what? yes its possible to use leds without resistors in an application that uses less voltage or multiple leds wired properly. but what does that have to do with my statement that there is no such thing as a 12v led? to be honest im probably a liar. i bet there is an led that takes 12v but its not going to be a standard looking led and nothing u can just pick up at radioshack or walmart or anything like that. no offence to the OP but someone looking at a real 12v led isnt going to be asking that question. im just saying
I would like to make reference to this How To post : https://www.cobaltss.net/forums/how-...ck-led-205878/
In which the author clearly uses 12v LED's that do not have a resistor attached.
And here is the link that the OP of said post provided for the website from which he ordered 12v LED's: 12 Volt LED
Old 10-29-2010, 09:16 AM
kento19's Avatar
Back to my problem. I visually checked every fuse now and still nothing? Somebody said reversing the positive and negative could stop the current. Is this true? If so how can I get the current going again?
Old 10-29-2010, 11:32 AM
scottydoh's Avatar
It doesn't literally stop the current from flowing to the board, they just meant that LED's only work in one direction. If you wire them up backwards they just won't light up. You should check out the How TO thread I referenced above its really well written and walks you through the process step by step with pictures.
Old 10-29-2010, 01:15 PM
kento19's Avatar
just the leds in the hvac controls wont light up? or all interior lights in the car such as the cluster and steering wheel control buttons. thats my problem, all my lights stopped working
Old 10-29-2010, 01:48 PM
scottydoh's Avatar
the individual LED's won't light up...if you having problems with everything just like everyone else, I'd say you shorted something and blew a fuse
Old 10-31-2010, 06:48 PM
kento19's Avatar
also realized tonight that my taillights arent lit either. ill replace the bulbs tomorrow to see if thats it but maybe its connected to my problem
Old 10-31-2010, 07:17 PM
EmperorJJ1's Avatar
you checked both fuse boxes?
well i stand corrected.
Old 10-31-2010, 07:22 PM
kento19's Avatar
yes i checked both . this really sucks. i dont think the taillights are related but still, my entire interior lighting other than the ones in the rearview mirror dont work
Old 11-01-2010, 05:16 AM
EmperorJJ1's Avatar
nope. either gm lan is fucked, the interior lights fuse is blown (inside fusebox) or theres a short in the wiring somewhere. hvac control isnt nessicary at all it can be unplugged completely without harming the car. if u havent tried unplugging it do so but if nothing changes then that sorta eliminates that as the problem
Old 11-01-2010, 06:15 AM
  #36
Nothin Stock
gotboost?17's Avatar
rip everything out and bring it to the dealer and be like wtf my lights
Old 11-01-2010, 02:17 PM
  #37
c4w18's Avatar
I actually have a HVAC cluster if you need it.....its working perfect, just needs some graphite wiped off it from when the cops dusted for prints when my radio got jacked couple years ago. let me know.
Old 11-02-2010, 12:48 AM
  #38
kento19's Avatar
really? how much?
Old 11-02-2010, 01:08 AM
  #39
c4w18's Avatar
make an offer lol. how's $15+shipping?
Old 11-02-2010, 02:41 PM
  #40
DaBuzzard's Avatar
Well, that would explain it - your park lamp fuse is blown. Since the cluster circuit gets it's power AFTER the park lamp fuse, they go out too.
This lets you know your tail lights are out when your driving at night, GM has been wiring them like that since the 60's
Do believe the fuse is in the under hood box......
Old 11-02-2010, 05:39 PM
  #41
kento19's Avatar
Perfect you were right. Park lamp fuse blown. Thanks for all your help. I don't need to buy the cluster but thanks anyway.
Old 11-02-2010, 06:15 PM
  #42
c4w18's Avatar
np man glad you didn't have to buy anything to fix your ****, i wish i had that problem
Old 11-02-2010, 07:41 PM
  #43
DaBuzzard's Avatar
No worries, glad you got it sorted
dennis69
10-20-2015 07:39 AM
justinchinn
10-02-2015 12:18 PM
Delta coupe
09-30-2015 08:11 AM
yellow dragon
09-28-2015 09:49 PM
Bohb
09-27-2015 09:11 PM
Quick Reply: Fail!! tried installing leds in hvac. please help
