Fan help...
Old 10-26-2008, 10:31 PM
06superchargedbalt's Avatar
Awesome, where do you wire it up at?
Old 10-27-2008, 05:14 AM
red06s/c's Avatar
theres a how-to for the whole thing over on localcobalt.net
Old 10-27-2008, 04:20 PM
red06s/c's Avatar
well it blew the 30a fuse today...now what?
Old 10-29-2008, 02:05 AM
EmperorJJ1's Avatar
max fuse size on 12g is 20 amps ... looks like u need a relay
Old 10-29-2008, 10:35 PM
stangthang's Avatar
I used to have this problem on older cars....70's and 80's cars... like EmperorJJ1 said, you need a relay. You can get them at an auto parts store for maybe $6 or $7..?? Buy a 25 amp or 30 amp relay. It is just a little black box with a few places to connect wire. They sometimes have a little wiring diagram on the top of the little black housing. A small switch just cant handle a fan. You still need the small switch. The small switch turns on power at the relay, and the relay sends power to the fan. Make sense?? Power goes from your battery or wherever to the relay, and then to the fan, with heavier wire. The relay has a "built-in" switch inside it. When you turn on the switch, it turns on the relay. So, you also need a smaller gauge wire to go from the switch to the relay. All you have to do is make sure you wire the relay correctly. Maybe use a power source for the switch that turns off with the ignition, so the switch kills power to the fan when the car is off. Otherwise, you will leave it on and the battery will be dead when you come back to your car. Trust me on that one. It WILL happen. For the switch, you can usually use a small 5 amp power source to turn on the relay. Ground the switch if it has a light or LED in it too.
Old 10-31-2008, 02:48 PM
red06s/c's Avatar
I replaced a few things and a switch and i really think its fixed now.
Old 11-01-2008, 05:30 PM
britt's Avatar
the switch may not be able to handle the amps that ur using..i helped a buddy put in underdash lights and we blew fuse after fuse, and they were 30 amp. i have the same exact lights in my car and dont have a problem using a 10 amp fuse. come to find out, he bought a new switch and now hes usin a 10 amp fuse now, no problems.
Old 11-01-2008, 05:51 PM
red06s/c's Avatar
One of the items i replaced is the switch, i went from 30a down to 20a and its good so far.
Old 11-01-2008, 07:23 PM
britt's Avatar
i think we used a 25 amp switch.
Sean Cummings
01-08-2020 10:17 AM
CobaltCoupeCrazy
03-13-2006 02:39 AM
FL@SH
12-30-2005 08:00 PM
Quick Reply: Fan help...
