Firewall Grommets?
Firewall Grommets?
I hate to ask but I am slightly stumped on where to run some of my audio wiring without drilling a hole and getting a grommet. Are there any existing ones, that I am just blind to, where I could make 2 runs of 00G? I see one below the steering column but it seems slightly too small for both runs, does anyone have any ideas? Thanks.
I'd be more curious why you'd want to source that large of wire from under the hood. Personally, interfacing as much as possible direct from the battery the better. May not be closer to the alternator, however it doesn't displace the flow of electricity by sourcing from battery. The stock wiring back to the batt is already pretty hefty, at most you'd need to upgrade that wire and then run all from batt still.
if your running wiring for a system why wouldnt you run it directly to the battery? it would be a shorter route and seems simpler since the battery is in the trunk.
Sorry for the book.
Spinner
How to Guide
36
06-21-2011 06:02 PM
secondstringsoldier
How to Guide
13
03-27-2008 09:48 PM
ExHondaMan
How to Guide
29
08-08-2006 07:36 PM
