Flickering electrical system. Help!!
I bought my 2005 cobalt with 109xxx i am currently at 120xxx. Ever since I had the car my entire electrical system flickers. Dash lights, headlights, brake lights, everything. The alternator and battery were checked and they are fine. Alternator powers everything back up properly and battery is strong. We checked a few grounds and cleaned power wires but still flickers. As the RPM's go higher everything flickers faster. If you have any suggestions I can try to check or information please let me know! Thanks
if increased RPMs makes it change that makes me lean towards a gound issue vs power issue. I was going to say check the 50a fuse and holder in the back for the BCM but id look into the front grounds and batt ground. hows the neg bat terminal as well? they are built pretty shitty and can be loose
