Fm antenna to xm antenna
You will lose radio reception going small like that even if you find one. You have to understand these things are engineered to fit the requirements to sound good, Gm would not of spent the extra 3 cents to make the stock antenna its size just for fun, its what the system needs to operate.
You could always do something like this:http://www.crutchfield.com/p_12044UA...a.html?tp=3449
Install at the top of the windshield or rear glass (inside), or do a little searching for a "stick on" grid type antenna for the rear glass - looks kind of like a defrost grid.
http://www.crutchfield.com/p_12044UA...=detailed_info
I prefer the remote one so you can mount it under the dash w/o having to run wire all over the car...
"I would suggest looking at other products. The reception is terrible. I have tried mounting it in several different spots and none of them worked well. I live just outside of the Chicago where you can get radio reception anywhere and the strongest channels only come in 50% of the time. Great concept for a product but not worth the money."
"The antenna seems to be directional. I can have a decent signal, make a turn and lose the station. I have it mounted on the dash next to the bottom of the windshield, so it is not obstructed by anything other than glass. A $10 mast type antenna works much better if you have a place to mount it. I do not recommend this product.
4 out of 5 people found this helpful
Was this review helpful? Yes | No"
Last edited by EcoTecDriver; 01-20-2010 at 05:08 PM. Reason: Automerged Doublepost
Have not tried one of either style myself so I will take your word for it.
Honest truth, the reception with the stock antenna sucks compared to the wife's Taurus or my 535 - which has great reception with the antenna in the rear glass with the defrost grid
Good thing I like the XM
