Front Door Wiring
Front Door Wiring
I have tried searching and I have not found anyone cover this (but I may be wrong)...
I need to install new wiring from the door speakers to my amps any suggestions. Or a link of another install.
Options for getting the wiring from the door to the car.
1. Run the new wiring 3/4 of the way thru the plastic flex come out drill a hole into the car and put gromment around the wiring
2. Run Completely in new flexible conduit from the door to the car.
3. Abandon running new wire to the crossover just tap the wiring on the inside of the car. (where would be the best place to tap and still hit the wiring after the factory amp)
Thanks in advance
Thanks in advance
Here is the pic of the wiring going thru the factory door plug its a little blurry if your going to install this use lots of wd40 when pulling the wire and putting the grommets back together
1 more question where is the factory amp
Driver or Passenger side
Found a pic of the factory amp but cant find it under the dash. This pic is of a 2005 is it different in a 2009.
about 1/2 the plug is not used, I drilled it out and was able to run a 12 and a 14 Awg. through the boot and plug without a problem. Have some Pics of it if you want.
n20saturn
09-30-2015 12:26 AM
