Fuse keeps blowing in wife's Tibby
There is an electrical gremlin in her car involving the Clock/Audio fuse and I have no idea where the faulty point is. I have unplugged the entire dash, CD player, HVAC, Hazards, all grounds behind the CD player. Everything behind the CD player that was plugged in is now unplugged and is still blowing fuses. There is another 10A fuse for Clock/Map light that has a large plastic case that just pops the fuse out, not removes it but that isn't the problem because both that and the Clock/Audio fuse are 10A and its blowing 30A fuses just as fast as 10A. I'm really baffled by this. Any ideas??
I want to believe that but all the ends are closed in butt-connectors. Unless a wire melted somewhere in miles of wrapped and bunched wires that's all done at the factory. If a wire is exposed, I would have to A: rip the whole dash out B: cut open probably 100 bunches of wire and examine all the wires by hand ... I'm not ready to do a weeks worth of stripping to go on a wild goose chase in the dash.
Yeah but did you replace the front end speakers, if so are they running off the stock amp or did you run them off an aftermarket as well?
If your running an aftermarket HU have you tried looking at your harness (adapter). When in doubt pull it out and put it back in sometimes its a little thing that you just can't see but rights it self when you re install
Is there an OEM amplifier under the passenger seat or something? If so there might be a possibility that a coin fell inside of the amplifier and the short is inside the amplifier and you need to shake it out. You understand what I am saying?
ya um no. if there was an amp under a seat it would be sealed up tight so the only thing getting in would be a liquid... and for ***** and giggles if a coin did get in an amplifier and is shorting **** out its probably fucked. a small wire can easily fry an amplifier now a coin that's jiggling around, ya ur best off throwing that **** away
Emperor, how do I go about running a fresh power line to clock and deck? Deck is more important than the clock, just wondering if we can just by-pass the fuse since a rewire seems to be a good way to go.
Just splice out the power to the deck and run into the other fuse?
ok sao i quit reading to see if anyone told you but the tibbys have a shitty thing called a taco box ( i know because a few buddys worked at hyundai when i worked at vw) and when it go's bad it will pop and spit fuses out and the whole thing needs replaced... very costly job from what i remember being told.
my friend told me that if u take a big enough arguement up with a higher up at hyundai about it they will tell the dealer ship to cover it under waranty no matter what ur mialage is at...he said they once did a car 100k over waranty!! its in a few of hyundai's car's u can try to google it or look it up rveryone i now that worked there called it a taco box but i am not sure... look it up on a tibby forum.
so... i googles and found nothing... go to the local dealership and ask a tech if a taco box means anything to him and see what he says... i swear to you i am not playing some sick joke just trying to help... im not an ass like that just helping out
he also said when the box go's bad its common for the turn signals to not work( they will stay constant on when u turn them on no flashing) and the "tacobox" looks like a whole ton of wires going into one big box and hince the name for taco box( might just be a hatfield hyundai thing to call it that but who knows)
I'm too JDM for you
