fusetap problems
fusetap problems
so i have a 10 amp fuse tap, and a 15 amp fuse, will that work? anyways i cant seem to get it to work even with a 10 amp fuse i pulled, so am i trying the wrong empty slots or what? suggestions?
you talking for a remote wire?, if so there is a black square module on the fuse block, to the left of that square black thing there should be 2 10 amp fuses right by eachother and one way down at the bottom of the block, out of the top 2 10 amp fuses, pull the bottom one(which would be the middle of all 3 of the fuses) and stick the tap on the right side of the fuse and reinsert fuse, i believe that is the console light fuse
