gauges going crazy
gauges going crazy
i have an 05 balt lt trying to hook up new head unit bought best but connecter for 20$ all hooked and they told me hook red wire up to power and when i do my gauges go crazy and have no sound any one have this problem? any adive would be great!
The only red wire you should be messing with is the one coming out of the harness of the new CD player. You need to hook that wire up to switched power for the radio's turn on signal. The easiest way to do this is like xav said, use a fuse tap on the sunroof fuse.
the switched ignition (red wire) wire on the harness you bought lines up with a LAN (data wire) wire.
by a relay and wire it to the low current accessory (brown) wire, that way you have radio on in ign & acc. key positions.
z28addiction
09-28-2015 12:03 AM
