gear shift lights (automatic)
im noticing that the p r n d ... letters are not lighting up in the dark, the dimmer is on all the way but my girlfriend keeps telling me they never did light up however im almost positive they did. can somebody tell me if they do light up what fuse that would be?
To change the bulb you need to remove the console trim around the shifter, the shift knob and the top plate on the shift assembly. After all that, you can lift out the white light housing and change the bulb by twisting and removing the bulb socket from the housing. It's a t5 wedge style bulb.
