Gm05
Gm05
is that the correct Scosche wiring harness?
says for 2000+ tracker and montana, but i bealive its ours also...can somone confirm that for me,it kind of urgent
no. it's the same harness as the 2004+ Ion
Metra 70-2102
the only downfall is there is no amp yurn-on on this harness. so if you have pioneer, connect the factory pink wire to your blue/white on the deck. and you'll need to run your own switched source still
Metra 70-2102
