Guage Install Help
Guage Install Help
currently installing three guages in the a pillar....as it stand now i have all three wired into one power line that taps into the fuse box with an "add a line"...the problem is only the first guage in the series is receiving power.....
so as i see it....my only option is to run independent power wires to different items...
so what items can i tap in to that are not constant sources i.e. 12v to cigarette lighters etc...or would it be smarter to tap into three constant sources and use three separate power switches (which seems really stupid and a waste of time and effort)....
basically....if you have three guages in a your pillar....what are you using to power all three?...and did you wire in series or three independent power sources....
Delta coupe
09-30-2015 08:11 AM
