Head unit questions
Head unit questions
Hey guys. I have a 06 ss/sc. I have a question about an aftermarket radio- specifically I am looking into getting a pioneer f700bt. I don't know as much about radios as I know about the mechanical side, so I guess what im asking is if some one can give me a parts list of what id need to install the f700bt. I have the factory radio right now. ive been doing some research on here an cant really find just a straight up hard list of parts. I also would like to add the XM module to the radio as I love xm. will my factory xm antenna work? what module and/or wiring do I need to make xm happen on the f700bt? if some one could be kind enough to give me a list of part numbers and descriptions so I can kind of figure out what I need to do, I would greatly appreciate it. Thanks!
Ok here's the stuff you need.
Dash kit:
if purchased from a local audio shop the part number should be BKGMK352
Radio Interface (harness):
C2R-GM11B if car has no onstar, if it does have onstar you need an OS-311B
Antenna:
Adapter BAA4B
Thats all you really need. Good luck
Dash kit:
Antenna:
Adapter BAA4B
Thank you for the quick response. So would a kit like this contain everything I need besides the XM module? http://www.ebay.com/itm/2004-2009-Chevy-Pontiac-DD-Radio-Install-Dash-Kit-Harness-Antenna-PKG220-/390423683699?pt=Motors_Car_Truck_Parts_Accessories&hash=item5ae710a273&vxp=mtr
Looks like that deck requires this part for XM to work
GEX-P920XM heres a link:
No problem, good luck with the install. Forewarning you have to remove the bracket behind the factory radio so the new one will fit, but other than that its pretty straight forward.
agentirons
10-16-2015 02:11 AM
09-28-2015 12:51 PM
