Headlamp Wiring Harness
Ok, so I just finished my first retrofit project only to discover I no longer have the stock wiring harness that connects the headlamp to the turn signal and the side marker. Can anyone give me any direction on where I could buy one or possibly how I would go about making one? I tried newgmparts.com but they said the harness is only sold as an assembly with the headlights. Obviously not looking for new headlights since I just built some. Any help would be much appreciated.
its nothing that you cut off. on the stock headlight assembly the high/low beams, turn signal, and side maker are all wired together and go into one plug. then that plugs into i believe its an 8 pin connector that runs back into the car. so basically if you were to remove your headlight from your car, the part i'm looking for is still connected to the back of the headlight
You can check with ssconnectors.com
The website isn't the best, but when I needed a harness for a project I was working on, I just emailed them what I needed and they made it. Worked great!
